In my scene. i am making a schedule for my heat-it thermostat in the bathroom
When in auto mode, Like: at 5am till 7am turn floorheating on... set target temp to 30.
If in the meantime i would like to adjust the temp... say not 30 but 25... then I would like to change to the new temp to the desired temp.. in this case 25degrees C
it still stays inside the loop, but only change the temperature to the new temperature...
How can i accomplish this?
AND:
-- Manual Mode = Sleep for 2hours then AUTO again
if (Mode == 'MANUAL') and (NewTemp ~= "30" or NewTemp ~= "23") then
    log("Manual Mode for 2hrs");
    fibaro:sleep(120*60*1000);
    fibaro:setGlobal("Mode_FloorHeating", "AUTO");
    fibaro:call(262, "setThermostatSetpoint", "1", "15")
In the meantime of (fibaro:sleep(120*60*1000); ) (2 hours waiting) i am not able to change the temperature, as it's waiting for the time to finish, how can i change that?
This is my scene:
%% properties
%% events
%% globals
Time
-- debug
local debug = true; -- true
local function log(str)
  if debug then
    fibaro:debug(str); end; end
if (tonumber(fibaro:countScenes()) > 1) then -- > 1
  log("Script already running.");
  fibaro:abort();
-- Thermostat ID
local FloorHeating = 262 -- Heatit Unit
-- Temp Sensor ID
local BathroomTempS = 263 -- Bathroom AIR Sensor
-- Get Temp (Target) Readings
local FloorBathroomTemp = tonumber(fibaro:getValue(BathroomTempS, "value"));
local FloorBathroomTargetTemp = tonumber(fibaro:getValue(FloorHeating, "targetLevel"));
-- Get Variables
local cTime = fibaro:getGlobalValue('Time');
local cDate = os.date("*t");
local Global = fibaro:getGlobalValue("Global_Heating");
local Bathroom = fibaro:getGlobalValue("Bathroom_Heating");
local Home = fibaro:getGlobalValue("Present_State");
local Mode = fibaro:getGlobalValue("Mode_FloorHeating");
local NewTemp = fibaro:getGlobalValue("BathroomSetTemp");
-- Global Heating on Weekday
if (
  (cTime == '04:00') and (Global == 'OFF') and
    (cDate.wday==2 or cDate.wday ==3 or cDate.wday ==4 or
      cDate.wday ==5 or cDate.wday ==6)
   ) then
  fibaro:setGlobal("Global_Heating", "ON")
-- Global Heating on Weekend
if (
    (cTime == '05:00') and (Global == 'OFF') and
    (cDate.wday==1 or cDate.wday ==7)
    ) then
-- School Holidays
if (
     (cTime == '08:59') and (Global == 'OFF')
    ) then
-- Global Heating OFF Daily
if (
  (cTime == '22:45') and (Global == 'ON')
   ) then
  fibaro:setGlobal("Global_Heating", "OFF")
fibaro:setGlobal("BathroomSetTemp", FloorBathroomTargetTemp);
-- AUTO MODE --
-- School Weekdays School at 7:00
while(
    (cTime > '05:05' and cTime < '07:00') and (Global == 'ON') and (Home == 'HOME') and (cDate.wday==2 or cDate.wday ==3 or cDate.wday ==4
        or cDate.wday ==5 or cDate.wday ==6)
    ) do
    log("Current Temperature: "..FloorBathroomTemp);
    log("Previous Target Temperature: "..FloorBathroomTargetTemp);
if (FloorBathroomTemp < 24) then
    if (FloorBathroomTargetTemp ~= 30) then
        fibaro:call(262, "setThermostatSetpoint", "1", "30")
          fibaro:setGlobal("Bathroom_Heating", "ON")
        log("New Target Temperature: "..FloorBathroomTargetTemp);
        log("Floor Heating ON");
        fibaro:sleep(2000);
    elseif (FloorBathroomTemp >= 24) then
        fibaro:call(262, "setThermostatSetpoint", "1", "23")
          fibaro:setGlobal("Bathroom_Heating", "OFF")
        log("Floor Heating OFF");
        fibaro:sleep(2000);
log("Wait 5 min for next measurement")
fibaro:sleep(300*1000);
    -- if manual adjusted while automode morning ON
    if (NewTemp ~= "30" or NewTemp ~= "23" ) then
        fibaro:setGlobal("Mode_FloorHeating", "MANUAL")
        log("Manual Mode Enabled");
         goto stop
    -- if nobody home and heating still ON
    if (Home == 'AWAY') then
       log("Away Mode has been Enabled");
       goto stop
while(
    (cTime > '07:00' and cTime < '09:30') and (Global == 'ON') and (Home == 'HOME') and (cDate.wday==7 or cDate.wday ==1 )
    ) do
        fibaro:call(262, "setThermostatSetpoint", "1", "30");
          fibaro:setGlobal("Bathroom_Heating", "ON");
        fibaro:sleep(2000);
        fibaro:call(262, "setThermostatSetpoint", "1", "23");
          fibaro:setGlobal("Bathroom_Heating", "OFF");
        fibaro:sleep(2000);
log("Wait 5 min for next measurement-weekend")
       goto stop
       goto stop
::stop::
-- MANUAL MODE --
--log("Current Temperature: "..FloorBathroomTemp);
log("Target Temperature: "..FloorBathroomTargetTemp);
log("Saved Target Temperature: "..NewTemp);
-- after 7:00 or 9:30  the return to 15C
if (Mode == 'AUTO') and (NewTemp == "30" or NewTemp == "23") then
    log("Auto Mode Enabled, Temperature set to 15 C");
-- set Heating Variable ON or OFF...
if (FloorBathroomTargetTemp > FloorBathroomTemp) then
    log("Floor Heating = ON");
else
    log("Floor Heating = OFF");
Edited by samuel
