Adding A secondary Controller on 4.100
So I want to maintain my Fibaro unit as my primary controller but add HomeSeer as my secondary controller to my ZWave devices. I think I understand the process and I can the commands in HS3 to "Receive Network from another controller" but how do you start this process on Fibaro...is it the
AddAdd "secondary" controller:
Starts controller learning process (LearnMode), which is used to add or remove the Home Center gateway as a "secondary" controller or to receive the "primary" network role.
process function?
Or is it as simple as putting Fibaro in learning mode then clicking in HS to "Receive Network from another controller"
Darren
JDid you ever figure this out? In a similar situation here
i have a secondary controler named Homewizard, works on 433 mHz
in VD i created this for my sunblind
local jT = json.decode(fibaro:getGlobalValue("HomeTable"))
local selfId = fibaro:getSelfId()
fibaro:call(selfId, "setProperty", "currentIcon", jT.icon.ZonnenschermOpen)
HWS = Net.FHttp("IP-adres",portnumber)
HWSReponse = HWS:GET("/password/sf/0/down")
