Very slow webinterface
Guest reiniertc
Guest reiniertc
Since a couple of weeks, the webinterface of my HC2 is extremely slow.
Login takes about 1 minute, after that switching between pages takes about 30 seconds.
I also use the api: reading information from the HC2 takes about 30 seconds,
but sending a command gets processed instantly.
It runs 4.1 firmware, I’ve restarted the HC2 a couple of times, but no improvement.
I also issued a support request at Fibaro, but pherhaps anyone recognizes this problem (and has a solution)?
Edited by reiniertc
corrected a typo
8 answers to this question
Whats the CPU and RAM utilisation like (under Configuration > Diagnostics)? Could be in an infinite loop somewhere and maxing out CPU or a lot of scenes taking all the RAM?
I've managed to do the same to my HUE lights before over the API by having an infinite loop that was taking all its resources and meant light changes were very slow. Maybe something similar here.
Guest reiniertc
    CPU is 0-5%,
    Ram: 42% used (6% buffer, 20% used space, 16% cache)
    Disk: 42% used.
    So looking at the specs, I would expect a snappy HC2...
    By the way: there are no more than 5 scripts active with a loop, and all scenes have only 1 instance
    The api is used only if a webpage is called to check the status of my devices, which is about 5 times a day
    Edited by reiniertc
    Agreed, it definitely doesn't look like it should be running slow. With the usual IT response of "restarting it" not working, then I think you are at the mercy of Fibaro Support. Only other things which are unlikely to help, would be to clear your browser cache and check the network speed between you and the HC2, make sure its not something external causing the network to be slow and making pages slow to load.
    Guest reiniertc
    I forgot to mention: the network speed has been tested and is normal.
    let's wait and see what options Fibaro Support can provide...
    Guest reiniertc
    update: the network speed is ok, but I noticed a 4% packet loss. That's not right, right?
    That is not right indeed. Hope you find where is problem, cable, connection or some network device.
    You should not get any packet loss on a modern LAN, I would check your connections and router/hub/switch to see where its being lost.
    Guest reiniertc
    Just got home, tested the same cable without the switch in between and.... voila! Normal speed and no packet loss.
    in other words: it was the switch!
    thanks for helping out
