Call URL via LUA Script for mobotix T25
bitshaker
Hello everybody,
please can anybody help me:
I have a mobotix T25. Via a URL like http://User:[email protected]/control/rcontrol?action=sigout&profile=~Door") I can open the door.
How can I build a button in HC2 (with virtual device?) to open this URL?
Many greetings,
Thorsten
Hi Torsten
you could make an ip notify to poort 8000 of the mobotix with a string compare in setup / event overview / message event there you define poort 8000
and then you make a ip receive with the string compare T25. (Door open)
next in fibaro you make the virtual device with in button 1 the exact same text  (Door open) and you define in general the same port 8000.
next in the mobotix in the menu setup /actionsgoup you can make the action if ip recieve then open door
suc 6
Edited by stefke
