Following the release of the new software update 4.1, I noticed in the release notes that you can now group the RGBW devices. Has anyone worked out how to do this? If so, can you give me some guidance please. I am quite new to Fibaro so it may be simple and I just haven't worked it out yet.
Yes it is quite straight forward.Go to one of your RGBS devices in Home Centre. Click on the spanner in the top right and half way down the general tab you will find a device grouping box containing other RGBW devices. Just click on the ones that you want to sync together and when you change the values or status on this one it will automatically change the other grouped with it.
I'm running 4.1 and haven't got any grouping box showing. Looks the same as it always does. This is when the RGBW module is setup as an output/input controlled device. I can only guess the grouping only appears when configured as an RGBW or RGB controlled device.
