robd 1
I have an "old" version of the zwave.me wallcs. the one with the 4 buttons. with sime LUA code I programmed the module to switch and dim some dimmers.
see a portion of the code above. this works fine.
Now I bought new wallcs modules and the same code is not working. so why not?
Well because the trigger property is gone in the new version.
the old version has a property "sceneActivation" the new one has not. see two screenshots.
who is responsible for this problem? Has Fibaro fogotten to implement this property in its code of is zwave.me forgotten to put it in the firmware of the module, or should I use another property?
the only difference in properties between the 2 versions is the SceneActivation
Link to post
16 answers to this question
