croostmx 0
Hi there,
I recently bought another couple of Fibaro Motion Sensors to go with the ones I already had in use.
I never had any problems with the Sensors I had already been using - those were with the old firmware (without ZW5/Zwave Plus) though.
Now the sensors I bought now, the ZW5 ones are producing all kinds of problems that I have no solution for as of now.
I'm not using HC as a Controller, but a Raspberry with IP Symcon.
The biggest problem is that the Sensor is triggering all the time, even when there is no motion at all.
For example in the picture below, it triggers all 10 minutes (that's the cancellation delay, set up in parameter 6) - it goes to FALSE for a second and then reports motion again.
As mentioned, those problems only occur with the sensors that have the new ZW5 firmware.
Did anybody experience something like that or knows how to fix it?
Or is there a way to downgrade the firmware to the penultimate version?
It can't be a sensitivity problem, I have tried covering the sensor completely - and it still behaves like this.
And I have bought 7 of these sensors, same story with all of them.
Happy for any help!
14 answers to this question
