all,
my hc2 has a zwave blackout, zwave just doesn't work, resetting the box doesn't help. Fibaro Support cleared the box a few times, but nothing helps. in the Devices tab, the Add en Delete popup windows don't show up. 4th zwave led is constantly burning on the box.
I guess the only way forward is a factory reset. Which isn't too bad because I've got loads and loads of ghost devices.
My question: If I go to recovery mode, can skip the Restore? I really want to start with an empty HC2 and build it up again from scratch.
cheers
emiel
4 answers to this question
Do you have powernode-6 devices? I eventually powered down the house group by group, until found that the greenwave powernode was flushing the zwave network.
Maybe give it a try.
    no, haven't got powernodes. And I already tried every trick in the book, including powering down the house.
    cheers
    emiel
    sure, simply chose "erase z-wave memory". After installation of latest version, one can still restore latest backup, but when you not restore it, the system will stay clean.
    Sure, you will have re-add all devices, but this is what you wish to do.
    correct! Thanks! Hope the weather isn't too good this weekend ;-
