Can anyone tell me the specified model Krups KP1000 coffee machine works with fibaro HC2 or not ?
I can`t find any z-wave module or connectivity for the coffee machine. Correct me if i am wrong and please reply as it is urgent .
Guest FredrikKarlsson
Sorry, but why would this particular coffee machine work with HC2 in any other way than other "not connected" machines.
Sure, it works. You insert a Z-wave plugin switch in-between the coffee maker's power coord and the powerpoint, and then you can switch it off remotely through HC2.
It will not allow you to start making coffee remotely though, I think, unless this particular maker has a "start making coffee as soon as the machine is switched on" setting.
And, of course, it will not enable you to insert a coffee capsule.. There are limits to the capability even for Z-wave. ;-)
