Satel-Plagin and advanced settings
Dear Ladies and Gentlemen,
I would like to ask you if it would be possible to icorporate the „device kind“(Picture 1) in the Satel-Plugin, so that this function enable to incorporate things like smoke detector, door sensor and water detector in „Satel-Alarmsystems“(Picture2).
First of all I would like to know if this possibility is given or not.
I hope to hear from you soon. I look to hearing from you in the near future.
Yours faithfully
Leutnant of Technical Arts S.K.
Hi guys,
Can I use LUA scenes to arm and disarm Satel zones? I have tried using fibaro:call(xxx, "setArmed", "0"), but for some reason it does not work...
What am I doing wrong?
thanks,
Ros
Ok - figured it out - the right lua command is fibaro:call(PartitionID, "disarm")
Fibaro incorrectly translates graphical blocks to LUA for this action
