Fibaro Dimmer will not shut off completly
francisco
installed a Fibaro Dimmer behind a Lamp with 4 LEDs (dimmable).
Working fine, but the light will not shut off completly. LEDs remains on lowest brightness.
Any quick idea?
Francisco
4 answers to this question
  • I think the dimmer is broke. He works fine during inclusion. I can change every parameter, but he won´t switch. It doesn´t matter if he is switched on oder off, 220V are the output of the wires.
    I doubled check the wiring, don´t see any mistake at all
    For diagnosis, replace one of lamps with a halogen or incandescent type, between 25 and 100 W. Set p13=1 to calibrate. What happens?
  • Problem solved, Dimmer works fine with a 40W lamp.
    Need to install a bypass for LED, thanks for help!
