Hi All,
I have made a blocks scene interval based. it is working well but i have a problem with repeat every 1 minutes or every other time.
the scene should work from 9 to 6 at morning. so it should not work form 6-9 at morning.
it is about that when i am opening the main door (breached) then hole light goes on and when i shut the door (safe) then wait 120 sec and turn the light off.
but if i put the interval time based option i.e. every 1 minute than it turning off the light after one minutes, because it is repeating the action every one minute.
otherwise i do not understand very well these interval time based situation. for me a bit strange that repeat situation.
i will paste my block scene.
i think it should be made with a variable, but to be honest i do not understand variable either.
si it would be some examples and help.
thank you in advance.
the second and the third is working, the first one is working too but it is problem with the repeating one minute.
