Can Fibaro modules send a signal to the home center?
Hello guys,
I was wondering if Fibaro modules (say for instance a Single Switch 2) can send a signal to the Home Center to start a specified scene.
Just like "The Button" does, but done by a module, behind a switch, neatly concealed in a wall.
And if so; Is there a specific module which can perform this task or are all of them able to?
Thanks!
they report status, so you can use that to start scenes. i do
if dimmer2 changes to on, then xx on etc etc
