Delete room bug
Guest cberbecaru
Guest cberbecaru
Today I tried to delete an unused empty room via the web interface and got stuck at the refresh screen (rolling balls) after delete confirmation. It is possible to login afterthat, but the wait screen last forever and you cannot interact with the box. Looking at requests (with F12), it seems that the problem is a malformed json response when querying for rooms, which ends prematurely immediate after the deleted room (which was NOT deleted). Recovered only after made a manual room API DELETE from /docs/
I'm not sure if this relates to 4.1 update as this is the first time I encountered it.
Just tested this function. Worked without any delay or freeze.
Can you clear your browser's cache, create a room and then delete it?
Guest cberbecaru
    I did cleared the cache when it happened, used other browser, etc. I'm sure it works because that was not the first room I ever deleted. What I wanted to report is that under certain circumstsnces it fails. I will try again to see if happens again and provide more info.
