So i have several RGBW and Relay sensors to connect. I want to put them in a special rack next to each other and from there to connect with wire devices (RGB strips, light bulbs etc.). Can somebody tell me will it be a problem if the sensors are side by side. My main concern is that there will be interference between sensors.
I have two roller shutter modules side by side in a wall box and work just fine. Also have two smart plugs next to each other and also never problems with them so it should work for you.
