Hello guys,
Ok so this is the LUA scene . Why I still get the notification? -> "Too many instances" .
Can anyone help ?    Ooo , and you can use this scene for RGB . Ex : When RGB 1 is green  -> 2,3,4,etc will become green .
Thank you :D .
%% properties
266 currentProgramID
266 color
%% globals
if (fibaro:countScenes() > 1) then
fibaro:abort()
local fromID = 266  --id RGBW principal
local toID = 251    --id-uri RGBW secundare separate prin virgula ","
function setTheColour (deviceID, colourString)
  local RGBWTable= {}
  local i = 1
  for value in string.gmatch(colourString,"(%d+)") do
    RGBWTable = value
    i = i + 1
  fibaro:call(deviceID, "setColor", RGBWTable[1], RGBWTable[2], RGBWTable[3], RGBWTable[4])
local trigger = fibaro:getSourceTrigger()
if (trigger['type'] == 'property') then
  if (trigger['propertyName'] == 'currentProgramID') then
    fibaro:call(toID, 'startProgram', fibaro:getValue(fromID, 'currentProgramID'))
    if (fibaro:getValue(fromID, 'currentProgramID') == '0') then
      setTheColour(toID, fibaro:getValue(fromID, 'color'))
  elseif (trigger['propertyName'] == 'color') then
I raised MAX running instances from 2 to 4 and have bold-ed code in my scenes and no more warnings. On 4.100 there is info for each scene when is triggered and how many instances is running and it is always 1.
    Thanks , I will try it !
    • 3 weeks later...
    And Daneasa is it working for you?
    Yes , is working .
    Thank you.
