martin_dino 0
To bypass clock lagging feature tried to implement cron script from another maschine to force ntp update.
At first i tried with curl:
curl -X PUT -H "Content-Type: application/json" -d '{"ntp":true}' http://IP:[11111|80]/api/settings/location --user admin:admin
After failing with curl i tried to test api from http://IP/docs.
Thought that maybe it's the problem with running api command's from different host.
But with /docs i use body: {"ntp": true} and the Response Body is "no content" and Response code is 500.
Can anybody help directing me to right direction?
