Richie1972 0
I have a Smoke Sensor FGDS-002
Manufactured: 2015 FEB 28
The other night the alarm sounded (not a triggered sound - a slightly longer sound) with a red light blinking.
It had not triggered on my automation system and there was no smoke.
The battery level was low, so i swapped out the battery (following the procedure to reset in the instructions)
A few hours later it went off again, so i removed battery and reseated it.
This happened a couple more times and i left the battery out until later the next day.
I put the battery back in and all was ok until late that night when it did it again.
I suspect that the unit may be faulty - i have three other similar devices that are all ok.
Has this happened to anyone else?
Also, what's the warranty on these? is it 12 months or more?
Thanks,
Richie
