Setting a Global Variable with Domoticz does not Work
Hi All,
Im trying to set a Global Variable on my HC2 using the "Fibaro-Link" function in Domoticz. The Log on the Domoticz showing no errors but the Global Value does not change.
Based on the following Link this should work without any problems:
Sending Data from a Domoticz device to an Virtual Device on my HC2 works perfectly fine.
Does anybody have an idea why I can't set a Global Variable. If more Infos are needed please let me know.
Thx!
Dnia 27.10.2016 o 16:54, namboy1 napisał:
Hi All,
I believe that you should contact Domoticz on this matter as well.
Hi @namboy1,
did you found a Solution?
Regards Hoggle
    Hi @Hoggle,
    I can't remember as I stoped using Domoticz. Sorry.
    Regards Rolf
