stop automatic light whith switch?
Guest pblacky
I use a small script for activating light (fibaro relais switch) in bathroom with an fibaro motion sensor.
this works fine but when anybody switches the light of by hand the script cant be reactivated with motion sensor bevore delay time (15 min) is over.
so maybe there is a hint, how i can stop (ore reset) the script when light is switched off by wallswitch??
Here is the script i use: (not my idea, found it and changed it for my use ;-)
Guest pblacky
    Really no hints for this question?
    is my posting in the right forumthread?
    I think what you need can be accomplished by making a scene that is triggered when the switch is pressed.
    When a switch is controlled by a momentary switch, you can use it to activate a scene, which in turn can stop the other scene.
    I kind of need the same you need, but I haven't implemented it yet.
    Anyway you will have to use the CentralSceneEvent from the first slave of the switch device as a trigger. I already have a working scene (found on this forum) that logs the keypresses, but I haven't used it yet, to cancel my other scene. do a forum search on "CentralSceneEvent" . That should help you in the right direction.
    Code for a scene to test if you get those events.
    Looks like this with my switch.
    Edited by TW1979
    This can be done with one scene that control this light. All you need to do is to check status of the light switch during countdown when there is no more movement (motion sensor is safe), and if switch is off then reset countdown timer to zero so that scene stops running.
