Easy LUA Scene
Hello, i'd like a manual LUA scene that when started (manually started) turns on a device and after 1 minute it switch it off and send a notification, then stop till next time i manually launch it.
I was thinking about something like this but ... something missed :P
%% properties
77 value
%% globals
local  schukoID= 77;
fibaro:call(schukoID, "turnOn");
fibaro:sleep(1*60000); -- wait 1 minute
fibaro:call(schukoID, "turnOFF");
4 answers to this question
modified the lua for you :
%% properties
%% globals
local  schukoID= 77;
the "end" statement and "77 value" shouldnt be there
what about the notification, where should it go to ?
Edited by diedvdyk
    It starts, but it does not stop (shuko keep running)
    example: hope it helps
    %% properties
    194 value
    %% globals
    if
     fibaro:getValue(194, "value") == '0'
    then
        fibaro:call(194, "turnOn")
         fibaro:call(196, "turnOn")
          fibaro:call(197, "turnOn")
           fibaro:call(306, "turnOn") -- Kettle socket
            fibaro:call(175, "setProperty", "currentIcon", 191);
    else
        fibaro:call(194, "turnOff")
         fibaro:call(196, "turnOff")
          fibaro:call(197, "turnOff")
           fibaro:call(306, "turnOff") -- Kettle socket
             fibaro:call(175, "setProperty", "currentIcon", 190);
    %% properties
    %% globals
    local  schukoID= 77;
    should be turnOff instead of turnOFF
