MU-Germany 0
Dear comunity,
I have a probleme with a block scene and hopefully someone can tell me, what I did wrong.
The scene's job is, to turn lights on / off at a special time, in case I am not at home(!).
I created a variable, that I can aktivate with another scene - that works good:
Set "Simu_Anwesend" = "Aktiv" means, I am not at home,
set "Simu_Anwesend" = "Inaktiv" means, I am at home and no lights should be turned on automatically.
The Problem-scene (see attachement) sould turn on a light, in case of I set the variable "Simu_Anwesend" to "Aktive" and the time is 18:00.
The problem is, that as soon as I set the varibale to "Aktiv", the light turns on immediately - even the time is bevore 18:00!?
Thanks for every help!
7 answers to this question
