Problem with json decode and boolean
Hello i want to parse that string and to check relays":[{"ison":  the status (true or false)
I have error when try to convert Boolean to integer like that:
[DEBUG] 17:44:16: false
[DEBUG] 17:44:16: [1;31m2016-11-06 17:44:16.291270 [ fatal] LUA error: /opt/fibaro/scenes/703.lua:36: attempt to concatenate field 'relays' (a nil value)
Same error is when i try logical operation like that:
If (jsonTable.relays[1].ison) == true then ...
When i try to make the same from VD:
i have error:
[ERROR] 18:09:40: line :debug (arg 2), expected 'string const &' got 'boolean'
but if i try
It's work.
Edited by kmeta
I've turned your question into runnable code, and it works on my HC2 V 4.100 in a scene. So I think I'm not getting the whole picture. Can you run this example?
