Fibaro dimmer 2 as pure scene control
Do anyone know if it is possible to use the Fibaro dimmer 2 as a pure switch without controlling any load or lights?
I do not have any cables going directly to my downlights, and i need to use a scene to control them. I have therefore wired them as shown in the attachments.
I have made a simple scene where the scene activation 16 on the dimmer inside the switch turns the dimmer controlling the downlights to opposite state. I have also enabled parameter 28 on the dimmer.
Why is this not working?The dimmer that controls the downlights responds perfectly to the fibaro app on my phone, and to controls on my computer.
5 answers to this question
" to "
Temat został przeniesiony z "
" do "
I Made the Same configuratie as the drawing with downlights. The dimmer doesnt work and is nog found by FHC2.
Anyone a solution?
You need a load connected to the dimmer2... a bypas for example wil work fine.
with "a load" you mean just a wire conection with 230 volts ? Gives no problems with overload?  On witch conection?  now there is a load of 230volts on "L".
sorry for my poor English.
kind regards Kees
I did connect N with Sx and blow up a fuse :mrgreen:. removed connection and replaced fuse.
Now its working fine and integrated in FHC2 :?::!::idea:
Edited by zaanhoeve
