Virtual device
Hi can someone help? I have  manage to add Vera edge lights (RF) to my Fibaro HC2 via virtual device I can control the lights on/off using the following command GET /data_request?id=action&output_format=json&DeviceNum=49&serviceId=urn:upnp-org:serviceId:Dimming1&action=SetLoadLevelTarget&newLoadlevelTarget=50 HTTP/1.10x0D0x0A0x0D0x0A . But I need help for adding a slider to control the dimming level.If that's even possible! I know this is not the right topic to post a such a question but I could not find  help anywhere else I hope someone can help me thanks in advance! If there Is any solution to my problem please explain the steps for editing a slider like on a five year old! I have my uniti from five days end I am absolutely incompetent but willing to learn!
8 answers to this question
Can you try this in the slider button in VD:
Simply put it in the box for slider button. Of course, change values so that it will use the ones you need.
    Hi thank you for your reply! Do I need to change the IP and the port number for my Vera? Please give me an example what should I edit!
    Which values I should change? Device on Vera is id 49!On Fibaro VD the ON end OFF button end the slider are id 26! I have paste the cod as it is but noting is happening! Can you be more specific please! Regards: Ka4ev
    21 hours ago, T.Konopka said:
    C2
    Hi Do i ned to finish the code with HTTP/1.10x0D0x0A0x0D0x0A ?Or just live it lake the one above? i have try every thing but is not working!!!!! Can you please make the code en i can paste it in the Slider box!
    I do not understand one thing.
    Why do you need Vera for this solution?
    I am a little bit confused about what you want to achieve.
    I am using The Vera Edge to control my RF Lights! I have manage to turn them on/off but i do not know how to ad a slider to the device!
    The cod you provided is not working!
    Substitute the slider value with __sliderValue__
    so for your example it will be
    GET /data_request?id=action&output_format=json&DeviceNum=49&serviceId=urn:upnp-org:serviceId:Dimming1&action=SetLoadLevelTarget&newLoadlevelTarget=_sliderValue_ HTTP/1.10x0D0x0A0x0D0x0
