can not add a virtual device to a scene....
Guest Jeffsgb
hey guys,  i just finished installing a media room using global cache, i created a virtual device to control, av reciever, projector, and apple tv. I am trying to create a scene but when trying to add it i don't see virtual devices anywhere to add it to scenes, im i doing something wrong?
Do you have HC2 or HCL? What kind of scene are you trying to make, magic or block?
Guest Jeffsgb
    I have hc2 and its a remote control using global cache, with block scenes im trying to do a scene to to turn on projector, reciver, apple tv, while the lights turn off.
    Since you have HC2 you will definitely get more from it by using LUA scenes. Disadvantage is that LUA needs to be learned. You can still make block scenes but you can't use VD as triggering device. I suppose that you will run this scene manually so then you can first put something that will never happen as trigger and then you can add VD buttons to be pressed by this scene:
    Edited by Sankotronic
    Attachment quota filled up / deleting older stuff sorry :-(
