How to store a table in global variable ?
I tried  :
--The table has predefined values:
--lights2checkstatus[1] = 0
--lights2checkstatus[2] = 86
-- I copy local variable (1 dimensional table)  to global variable :
fibaro:setGlobal("LightsStatus", lights2checkstatus)
--where  lights2checkstatus is 1-dimension table (0,86).
-- I copy global variable to local variable  "lights2checkstatus1" :
local lights2checkstatus1 = {}
lights2checkstatus1 = fibaro:getGlobal("LightsStatus")
-- I debug values of local variables "lights2checkstatus" and  "lights2checkstatus1" :
 fibaro:debug(lights2checkstatus)
 fibaro:debug(lights2checkstatus1)
 -- The result of debug is eg. :
 table: 0x8731ca0
 table: 0x8731ca0
Which means  lights2checkstatus and lights2checkstatus1 are same.
There was read from the global variable the same what was earlier written to it.
 But each time I rune the scene (with the same values of the table (0,86) )
 I have different values :
table: 0x8828500
table: 0x8828500
table: 0x93f6938
table: 0x93f6938
and so on ...
What I do wrong ?
How to store in a global variable a table , eg. my test table (0,86) ?
8 answers to this question
You cannot use fibaro.debog or print for tables.
If you want to dump a table you must dump it by iterating through table.
Also for saving/restoring a table in global variables you might use json.encode and json.decode.
    Alex,
    Thank you very much for the hint. I managed to store and read back the table to/from Global Variable.
    Hi Alex / Gucio1234,
    Would you mind explaining how you did this loading and saving of a table from and to the Global Variables please? I am a senior programmer (VB.net/C#) but am only at the beginning of my journey with Lua and Home Center 2. My final aim is to share tables of information between scripts but the Global variables page is very limiting and I cannot seem to find any solutions on the forum.
    This is an example of an array/table that I want to be able to access by different a shared script or file. The data within the array is not static and requires changing by multiple scenes.
    local lightArray = { }
    lightArray['192'] = { 'Kitchen', 195, 1, 40, 360 }
    lightArray['125'] = { 'Hallway', 64, 0, 0, 60 }
    lightArray['11'] = { 'Living Room', 84, 0, 0, 360 }
    lightArray['72'] = { 'Office', 21, 1, 80, 360 }
    lightArray['167'] = { 'Landing', 58, 0, 0, 60 }
    Any ideas? Any help would be most appreciated.
    Cheers
    Trev
    Edited by TrevorNewsome
    Thanks but I think I have found a solution having searched JSON variables. Thanks alot though.
    TrevorNewsome,
    Here it is :
     --WRITE INTO GLOBAL VARIABLE "LightsStatusIn" the content of local array "lights2checkinsidestatus":
      fibaro:setGlobal("LightsStatusIn", tostring(json.encode(lights2checkinsidestatus)))
     --WRITE INTO LOCAL ARRAY "lights2checkinsidestatus" the content of the global variable  "LightsStatusIn":
      lights2checkinsidestatus = json.decode(tostring(fibaro:getGlobal("LightsStatusIn")))
    Edited by gucio1234
    update
    Hi
    Can you please write a simple LUA  to write the content of for example variable "weatherstate" table to a global variable "RainAmount"
    Edited by JEAU
    @JEAU
    as wrote earlier :
     --WRITE INTO GLOBAL VARIABLE "RainAmount" the content of local array "weatherstate":
      fibaro:setGlobal("RainAmount", tostring(json.encode(weatherstate)))
    Thanks a lot for your reply that worked, can I ask another question, How to see the content of a Variable Table
    @JEAU,
    again as I wrote earlier :
    --WRITE INTO LOCAL ARRAY "weatherstate" the content of the global variable  "RainAmount":
      weatherstate= json.decode(tostring(fibaro:getGlobal("RainAmount")))
