wienog 107
A few months ago I posted a similar message as this one saying that especially scenes triggered by (often Fibaro-) motion sensors were starting erratically , sometimes after 1 sec sometimes after 4 sometimes after 15 seconds only.
Several items to check were given to me: look for some endless loop, check for VD's with buttons that have magically disappeared, check out Lua-scenes for errors or typo's, reconfigure every device, rebuild your mesh;....
Well,I have spent the last two months doing just that. I have cleaned up my whole operation, removed unused scenes, rewrote scenes that looked suspicious , etc..
Guess what: HC2 is STILL responding very erratically to Fibaro motion sensors (and other triggers but that is less obvious because you can not literally SEE when they are triggered).
So what happens:
A scene that is triggered by a motion sensor takes sometimes 1 second, sometimes 5 or 6 seconds, sometimes 10 to 15 seconds before it starts. There is absolutely no other factor that changes with this behavior (like: it happens only when it's cold or when the cat is outside or aunt Anna is visiting).
THE SAME SCENE started from the webinterface or the (IOS-)app executes 100 % of the time IMMEDIATELY, without ANY delay.
So, i see the led of the motion sensor coming on and have to wait patiently what will happen this time: will the light go on immediately or only after 15 seconds, after i broke my legs in the dark on the stairs ?
So, somehow HC2 for some reason that I just can not find, AND ONLY SINCE 4.09x reacts slowly and erratically to triggered motion sensors.
Any ideas ? PLEASE ???
P.S.: 99% of my motion sensors are in direct contact with the HC2. Increasing sensitivity of the sensor doesn't help a bit: the sensor triggers, it's the HC2 that responds erratically to the trigger...
Edited by wienog11 answers to this question
