Virtual Device POST or PUT not working
I am sending the following via a Virtual Device button:
The webserver at 192.168.0.230:8080 receives the PUT request correctly, however the payload/data of the request (i.e. {"status":1}) is not sent.
Does anyone have an example of a PUT or POST request that correctly delivers a payload of data?
I've tested this on an HCL and HC2 and it doesn't work on either.
The reason I'm not using lua is I need this VD to work on both HCL and HC2.
Thanks!
the following code works for me
