Breached and Armed bug?
--  EDIT --
Seems like it is Tamper tripped everytime one opens the door, even if it is disarmed.
If I delete the Tamper tripped then it does not send the notification when the Device is disarmed and I open the door.
I'm not totally sure this is a bug, or if I've done something wrong, but here it is:
1 door sensor. All the Device settings for notifications are set to "Do nothing".
1 Scene: (Door == Breached and Armed 0s OR Door == Tamper tripped 0s) THEN Push myPhone Door Breach 0s.
What happens is that I get the push notification even when the door is Disarmed.
Edited by robw
Hmm,
are you sure that this line is OK? If i understand you correctly, there should be "AND" between the conditions.
Other way it will be triggered always when tamper will be tripped.
" to "
Temat został przeniesiony z "
" do "
    22 hours ago, jbarnas said:
    Hmm,
    Oh, then I misunderstood it :oops: I kind of thought that if I put an "AND" inbetween, that both the door would have to be opened AND someone would also at the same time have to tamper with the device (open the case), before sending the message. That was why I put and OR inbetween. I thought it should send a message if 1 of those 2 options happened.
    I'll test put an AND between them! Thank you so much for your help! :)
