LUA Scene Documentation
I'm looking for some basic Lua scene documentation.
Is there documentation for instance describing the Triggers:
%% autostart
%% properties
%% globals
Presume there is some documentation that explains what e.g Autostart means (when is it executed/triggered) and which proporties are valid (aside from ID Value), e.g. can you trigger on certain device types?
Can;t seem to find docs on this. Thanks
4 answers to this question
Guest chaicka
Edited by chaicka
    Thanks, did not know about the Docs on the fibaro HC2. Still I can't find anything on the Triggers as mentioned above. Surely there must be info on this?
    Hi maybe this help you
    or here:
