Hi there,
I've finished few projects with fibaro HC2 and different modules and everything works fine.
Now I'm planning a new big one. There is gonna be installed many LED lights which works with 0-10v dimable
Fibaro itself doesn't make any useful modul. After few hours browsing I've found few solutions.
1. Qubini flash dimmer
2. 0-10V PWM Digital to Analog Signal Tranformer Converter Module MACH3 PLC
3. User HomeSystem.sk said:
Ok, we figured it out
/uploads/emoticons/default_biggrin.png" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" style="vertical-align:middle;border:0px;" width="20" /> Dimmer really not going to work with this, neather RGBW modul. But surprisingly, when we connected relay switch to DA, as far as the relay is ON the panel is dimming in the circle. Not perfect, but it works.
So double relay switch is the solution - Q1 is taking care of ON/OFF and the Q2 of dimming...
The best solution should be Gira 542100 which I use in enet projects. But not compatible with HC2 (I guess)
I probably go for solution 1. Qubini flash dimmer
I'll be glad if someone know an other new solution.
" to "
Temat został przeniesiony z "
" do "
