erip-eri 0
I made a Lua scene which was supposed to control the ventilation system in my house based on CO2 measurements with a Netatmo Weather station. I couldn't get the Lua script working the way I wanted (way too much air flow on cold days) so I decided to make a simpler block scene version. And I deleted the Lua scene. The problem is that the deleted lua scene keeps on working even after multiple software updates and multiple reboots. I cannot see the scene anywhere in the user interfaces (Web, Ipad or Iphone) but I know for sure that it is running.
Is there any way to find this script in the system and delete it completely instead of just remove it from the UI?
[edit] solved already, in the webinterface, dashboard. I added a panel scenes in which this scene was visible. It turned out that the scene was marked "hidden" and not deleted.
Edited by erip-eri0 answers to this question
