VENTILATION - does anyone have that in HC2?
Guest jfu
Does anyone have expirience in managing ventilation (or recuperation) by Fibaro system?
On the webpage it looks very promissing but I havent found how to implement it in real.
Guest jfu
    Myself, I've finally decided to go for Termostat Man Coil Z-Wave MCO Home MH8-FC, which will control ventilation unit and temperature as well.
    By the way, does anybody knows what means "2h 0m" in below picture?
    I can't see first image
    Guest jfu
    Hmm, that's strange. I see it.
    Please check now (attached to this message).
    i think that tell s u wenn that was triggered last time - which would be 2 hours ago ( if im right)
    i think i was wrong - the other aswer below is right :) - dont want to confuse u
    Edited by confesor
    as far as I Know, when you set a different temperature from Gui (in the example you are setting 18° when Danfoss temperature is on 23°) , this new setpoint is active for the time specified in that field.
    So after 2 hour, HC2 tell danfoss to revert setpoint to 23°
    Guest jfu
    I guess it's not it.
    I've changed 24 > 18 at 7:00, automaticaly "2h 0m" has appeared.
    Now it is "0m" but still 18.
    On my system work exactly in this way.
    I've got my danfoss "cucina giardino" set to 21.5°
    Then I changed it to 22,5° (when danfoss wake up it read 22.5°)
    Then when timer ends , it will revert to 21.5° (and when danfoss wake up again it read the new value)
    BTW : Every time need to wait until danfoss wake up , or you have to manually wake up it.
    Anyone can say how it have to work ?
    Edited by candrea77
    Guest jfu
    Apparently it works only when You change to higher temperature.
    if You change to lower it stays all the time.
    I'm wondering what is the reason of this function... the aim of Fiabro is to control the devices not devices to control themselves.
    On 12/12/2016 at 8:49 AM, jfu said:
    Thanks candrea77. I think Your solution is reasonable, probably I will do the same.
    I'm going to ask Fibaro team about this ventilation icon on ipad's main screen (how to activate it).
    Hi @jfuHave you got any answer from Fibaro so far or found a solution ? I also want to use that icon instead of having it greyed while the ventilation is running.
    For those who are interested I have a ComfoFan S Zehnder controlled by a 0-10V output from Qubino. The creation of a VD is straight forward, however how to hook it up with the icon on the home screen of the ipad...
