I'm looking for schematic for a Fibaro FGS-213 to way switching with three buttons. How should i connect?
Have a look at "figure 4" here:
It's for the FGS-211 but the input diagram for the FGS-213 is the same (the output is somewhat different. But that's in the manual).
    Thx, do you have a more accurate diagram where I see which of the buttons I'll connect FGS-213 on and and how I connect exactly
    I' m sorry, I don't there is a better one. What I would do is this. Follow the wires and give them a name (a, b, c, ...) and write down what each end connects to (eg " a1 connects to bulb, other end, a2 connects to terminal "22"of "switch 1" or whatever marking you have on the switch.) label the wire ends too. Then you can draw a schematic and match it with the diagram at Vesternet. To check if you've done a good job, just imagine if you would be able to take everything apart and then put back by schematic...
    " to "
    Temat został przeniesiony z "
    " do "
