Does anyone have a nice idea how to solve the problem where a flood sensor which is placed under the kitchen sink cabinet goes dead constantly. The only idea I have is that the signals can't go through the drawers I have in the kitchen..
The HC2 is located like 6 meters away from the kitchen.
Regards
Install the flood sensor with a 12V/24V  2/2.5A  power adapter and you have a Z-Wave repeater !
or install nearby +/-1m of the flood sensor a FIBA wall plug FGWxx-102 ZW5 it's also a Z-Wave repeater !
extra tip for the first time including a new device ,max 1m nearby of the z-wave gateway with min 2h power on
and make a backup before including a new device and after good communication with the new devices a new backup !!!
Good Luck:-)
Regards
Danieldb
    Thank you for your reply. I never thought of the repeating technique. Will absolutely look into that. Thanks
