Hi All
Could anyone tell me if the Hikvision® DS-2CD2135F works with the plugin on the HC2.
I think it using RTSP and RTSP protocol is not implemented in Fibaro, if I'm not mistaken.
Searched here
afaik DS-2CD2135F should support mjpeg as well, which is exactly what you need to get it working with Fibaro
    I just don't want to buy if not going to work as I bought the nest thermostat and now that's been taken off the plugins. I think Fibaro think we have got endless amount of money to keep throwing at this.
    nobody said you have to buy something. Simply check with hikvision, if that model support mjpeg (DS-2CD2135I and DS-2CD2132F have both mjpeg stream). All you need is cam with mjpeg, nothing else (it must not be plugin, you can use manually created cam as well).
    Why mention only FIBARO and not NEST alike? I read some bad things about NEST and their customer support. It is not that I take it for granted, but still?
    I use HIKVISION DS-2CD2120F-I with my Fibaro.
    The Fibaro plugin I use is :        HIKVISION ds2cd2132i
    The path for video stream I use is:        Streaming/channels/1/picture
