DjHedan 0
I have a lot of Vitrum sattelite switches. When I sign a Vitrum button to the Fibaro actor dimmer or switch 1x3KW, 2x1,5KW.
I can not sign another Vitrum sattelite button on another location in the house onto the same dimmer or switch actor. The actor dissapears when it's signed the first time to the Vitrum sattelite switch.
That mean I can not turn on/off same dimmers or actor switches on different Vitrum sattelites buttons that are located in different areas in the house.
Another problem is when dimming from Vitrum Sattelites the dimmer dims light down but the dimmer value increase as soon as you release the button on the Vitrum Switch again.
Hope we se a fix soon.
Best Regards from Sweden Mikael H.
Edited by T.KonopkaImproper title - give other an idea what you are posting about. Wrong category - no indication that the issue is connected with the update.
4 answers to this question
