ivhansen 6
If I fetch the last breachedtime from sensors they are not in sync with the timing found in the event panel. This code:
DoorMotionTime = tonumber(fibaro:getValue(xxx, "lastBreached"));
Will fetch a timestamp that may be later than the value shown in the eventpanel. Is my method wrong or do I not understand the "lastBreached" method? Should I fetch the timestamp of the last breach/safe from the log instead (and how to do that)??
My sensors are Fibaro motionsensors. Could something else than a motion (ex temperature or LUX) affect the lastBreached reporting from the sensor??
Edited by ivhansen0 answers to this question
