Power measurement - Fibaro double switch
Guest Lode
I have one Fibaro double switch 2 with power measurement.
In previous versions it worked well altough i'm not sure about the accuracy.
This morning I saw that the power it uses does not show up in the gui.
When I poll the device it shows up.
When I shut down the device the power the device uses doesn't disappear, only after polling it does.
Other devices with power measurement work normal.
Another things I saw is that the device has four slaves instead of two.
One of these slaves is a slave from a smokesensor !!!
Please, contact our Support at [email protected] . The issue should be addressed by one of our engineers.
Guest Lode
    Ok thanks:-D
    " to "
    Temat został przeniesiony z "
    " do "
