Hello
Good afternoon.
I have a DoorBell Aeotec, I tried use it, but was impossible because I don't found what is the trigger of the scene through wireless button.
any help please.
Edited by T.Konopka
Why would you post it in Crowd's Solutions? Did you read the description of the forum?
" to "
Temat został przeniesiony z "
" do "
    Hello
    I solved it with help AEOTEC support, I only change parameter 80 to 2 and ready.
    for any person need it in the future use.
    thanks
    Hello I created other scenes for DoorBell, maybe this aren't great for you. I know there must be another way to do it, but this working for me.
    Used the DoorBell for 2 functions, 1.- when the wireless button are being pushed by someone. or 2.- when the fron door is open.
    for case 1.- the doorbell active the scene and send  photos and e mail and active the video gate.
    %% properties
    140 value
    %% globals
    local sourceTrigger = fibaro:getSourceTrigger()
    if (sourceTrigger["type"] == "property") then
        if ( tonumber(fibaro:getValue(140, "value")) > 0)then
                   fibaro:call(136, "sendPhotoToUser", "2")
            fibaro:call(135, "sendPhotoToUser", "2")
          fibaro:call(2, "sendDefinedEmailNotification", "7");
    for case 2.- the doorbell active the scene only for say the recorded message in the memory doorbell.
    %% properties
    20 value
    %% events
    %% globals
    if (
     ( tonumber(fibaro:getValue(20, "value")) > 0 )
    or
    then
            fibaro:call(7, "setColor", "0","255","0","0")
              fibaro:call(141,"pressButton","1")
              fibaro:call(141,"pressButton","3")
              fibaro:sleep(3000)
              fibaro:call(7,"turnOff")
    I used 2 escenes and 1 DV (with 3 button)
    1 button DV
    C2 = Net.FHttp("127.0.0.1", 11111)
    jtable = '{"properties":{"parameters":[{"id":6,"size":1,"value":0},{"id":80,"size":1,"value":0}]}}'
    HC2:PUT("/api/devices/140",jtable)
    2 button DV
    HC2 = Net.FHttp("127.0.0.1", 11111)
    jtable = '{"properties":{"parameters":[{"id":6,"size":1,"value":1},{"id":80,"size":1,"value":2}]}}'
    3 button DV
    jtable = '{"properties":{"parameters":[{"id":6,"size":1,"value":6},{"id":80,"size":1,"value":0}]}}'
    when the door is close
    %% properties
    20 value
    %% events
    %% globals
    if (
     ( tonumber(fibaro:getValue(20, "value")) == 0 )
    or
    then
              fibaro:call(141,"pressButton","2")
    As you can see, I play with the parameter 80 and 6 to the DoorBell.
