How to connect HC with monitor with VGA
Guest Lode
Fibaro support told me to connect my hc to a monitor or tv with VGA/HDMI cable.
I did that but i can't get connection ?
Any ideas ?
and what exactly did you connected, tv or monitor? are you sure, the proper input has been selected?
power off HC2 and power it then on again, you should see at least bios screen at startup.
Guest Lode
    Connector on my tv to port 4 hdmi, selected source on tv was hdmi 4.
    Shut down hc, start up hc everything as you described.
    Same with PC monitor.....
    Can't see anything......
    " to "
    Temat został przeniesiony z "
    " do "
