Is it possible to use harmony activity status to run a Fibaro scene?
What I am trying to achieve, is to have a Fibaro scene run, automatically, when a harmony activity is run --
For example, Harmony scene = Watch TV, pressing watch tv will change activity state to "On"
I would then like to have scene, close blinds, run - and when activity state Watch TV changes back to Off, have scene Blinds Up, run.
Is this possible, if so, how?
5 answers to this question
" to "
Temat został przeniesiony z "
" do "
Yes it is possible, Jompla and me have the scene ready, I will make a blog post about it (and a video) as soon as fibaro fix the reporting the logitech status to Fibaro, as it is not working now (Fibaro does not read the status of Logitech when you use Logitech remote).
Guest Sarzeau
Hi, this would be very interesting for me too! Could you please publish the scene?
Thanks!
TT
hi
i actually do the opposite. i use fibaro to trigger the harmony scene and it works well.
i trigger the watch movie scene and that then closes blinds, adjusts lights etc and then triggers the harmony plugin to run the watch movie scene.
for the reverse though i switch everything off using remote then i activate the 'cinema off' scene to open blinds (if daytime) and adjust lights etc but also the change the harmony plugin status to 'off' as the remote cannot do due to limitation explained above.
