[SOLVED]HC Lite Hangs all the time
hi
whenever i want to do something with the iPad app, or through the webinterface
the system is unresponsive most of the times, then only option is to unplug the system, and let it reboot
sometimes it will let me restart services from the webinterface
this happens something like 3 to 4 times every day !!!
it started happening after firmware upgrade 4.082, on this version it would be ok (i had it 42 days online)
now if i'm lucky i can get it to be a few hours online
i run version 4.105 on the Home Center Lite, i tried to downgrade it to 4.082, but was unsuccessfull doing so
i have 18 devices in the Z-wave network, mostly smart wallplugs
i assume this isn't normal, so any clue on what to do to resolve this is welcome
klaas
13 answers to this question
unfortunately it is.
The only possible way to get it working is to create an automatic restart each day.
But if you say that it get stuck 3-4 times a day then you do not have a big chance.
    i tried with this code found on the forum, but that doesn't work,
    pushing the button should work also i assume?
    POST /api/settings/reboot HTTP/1.10x0D0x0AHost: 192.168.1.11 0x0D0x0AOrigin: http://192.168.1.11 0x0D0x0AContent-Length: 00x0D0x0AAuthorization: Basic a2xhYXNAZGV6d2FydC5vcmc6YWRhYzRVU2s= 0x0D0x0AReferer: http://192.168.1.11/fibaro/en/configuration/0x0D0x0AX-Requested-With: XMLHttpRequest0x0D0x0A0x0D0x0A
    This restart the HCL. You can trigger it with a scene. I use a scene to trigger it every midnight:
    in the main VD page set your "HCL IP address" and port: "11111"
    as VD string write:
    Host: 192.168.1.10 [change with your own IP address]
    Authorization: Basic XXXXXXXXXXXXXXX [change with your own administration login]
    you can find here in the forum plenty of topics with examples
    i needed to add a label aswell, now it works
    Edited by Klaasz
    forgot to add label
    Hi Flowy/Klaasz,
    I'm confused on the Authorization: portion. Lets say my loginID is abcd & password is wxyz.
    Software Version:4.100
    IP Address: 192.168.1.5
    Port: 11111
    Host: 192.168.1.5
    Authorization: Basic abcd:wxyz
    or
    Authorization: Basic abcd:d3h5eg==
    Please kindly advise. Thanks a million.
    Edited by David Goh
    hi, the whole abcd:wxyz  needs to be coded, not just the password
    i ditched my lite and bought a HC2 instead :-)
    That's too expensive.
    Anyway, I believed I got it to work (Thanks to Flowy). I missed out the word, Basic followed by the coded abcd:wxyz
    Great, put it in a scene that calls the VD at midnight and you'll have the automatic daily restart.
    I have it since weeks and it "works".
    One exception was a day when it did not retrieve the time from internet after the restart and so the heating scheduler was messed up.
    Yup, currently configured as thrice a week & shall monitor for any more weird behaviour.
    -->i tried to downgrade it to 4.082, but was unsuccessfull doing so
    It works Look here
    Hi hoschi_66,
    I got it working already. Now carefree no stress on it. Thanks a lot.
    Hi everybody,
    I have updated to v4.110 few days ago, and have noticed that every night precisely at 00:00 (I noticed that reading history of my temp devices), it crashes. Obliging me to restart services through web interface when I wake up.
    I have no scene triggering at 00:00, and don't understand where this can come from.
    Would have an idea ?
    32 minutes ago, seduffes said:
    Hi everybody,
    start your new topic in:
    Home/Fibaro International/Fibaro System Update/Home Center Lite/Update 4.110
