kristofre 1
I was wondering if you guys could help me out by pointing me in the right direction.
The next step in my home automation project is adding the bathroom ventilation.
At the moment, this is done by turning a manual dimmer:
This activates this fan (I have rotated this picture as it is hanging upside down on the sealing) :
I have done some research and found that a lot of people do it with a Fibaro RGBW module, or with a Fibaro in-wall switch.
What would you guys recommend.
Dimming is not crucial, as I would be automating the running of the fan with a humidity sensor and would switch it off as soon as possible.
However, manual control is kind of a must for me. I don't want to not be able to turn on the fan if the HC2 is down.
If you need any more info, please let me know!
Thanks for your advise!
Cheers,
Kristof
