i have the new Sesative Stripes Version 0.6 with HCL2 4.100 and there is now an alert.
Devices without templates
Is there any Template available?
Greeting
Marco
run (once) attached LUA scene to assign template for v0.5, refresh notification center view and refresh browser view.
When ready, you can delete (or disable) this scene, it is only necessary to be started once
good to know.
are there also methods of doing this with qubino templates ? hehe
no, because one need existing and matching template.  For modules without matching template it is only possible to assign none-used template (to disable any "missing template" messages) and then to disable the usage of it (to be able to set parameters manually). Check my postings, i did posted this solution already here in the forum.
  • 7 months later...
a have version 0.7
What wil this scrript do to the device or does this change the template?
nothing, Fibaro have blocked this functionality for security reason (e.g. one could assign something wrong and "damage" the system/settings for particular device).
