VD for Tellstick Devices using Live?
abigbear
I've recently moved to the ZWave world when I bought a HC2 and some devices. But I still have some i Nexa and Telldus switch devices I can use outside and have not found any suitable ZWave ones. Therefore the idea to control the Nexa/Telldus devices using HTTP requests to the API of Telldus Live. Just simple things like turn on and turn off the switches. The IDs of the switches I thought I could input into the LUA code of each Virtual Device to keep it simple.
What I don't seem to find any good information about is the whole Oauth thing with authorization requests, access tokens and stuff until I can finally to the request regarding the switches. Has anybody any clues or hopefully already has done this successfully?
I found some documentation on the APIs at Telldus:
 (only PHP examples I don't really understand, strange language PHP) and then some more 3rd party doc at
Need help/directions both on how to do the http-requests in LUA and the more Telldus API specifics.
Once I understand those important things I'm sure I can get rest of the VD to work, it should be little more than on/off buttons and maybe some status message... We'll see once I get there.
Look forward to some input and/or experience in the matter...
Kind regards
Bjorn
Guest Eriond
Two years has passed, and there are no replies. Did You ever manage to integrate the Tellstick or any other 433-device for that matter?
