TheFurious
Aeon Multisensor 6 - LED
Hi all,
A happy new year! since a few days I'm proud owner of a Fibaro HomeCenter 2.
I tried to include an Aeon Multisensor 6. it worked so far and it also sends data of all sensors. The only issue I have is that the LED blinks every 11 seconds. It seems like a issue between the HomeCenter and the Sensor. I tried all available Firmwares but nothing worked. Are you guys having the same issue? If no could you share your confit or give me a tip how Tonwerk around that?
The sensors are USB powered btw.
Thanks in advance
Share this post
Link to post
you are in the HCL area of the forum.
Move your topic to HC2 to get help from its users
Share this post
Link to post
" to "
Temat został przeniesiony z "
" do "
Share this post
Link to post
Go to the Advanced tab of the MS6 device.
Turn off the "Use template for parameters" and save.
Add a new parameter:
/monthly_2018_04/image.png.cd402fcff4d64289aa665559467cbaf3.png" alt="image.png.cd402fcff4d64289aa665559467cbaf3.png" />
So parameter 81, with value 2 for total disabling of the LED.  This apparently only works from MS6 firmware 1.10 and higher).
Once this parameter is added, you can turn on "Use template for parameters" again (and save).
You won't see the parameter 81 in the template, but it's still there and it works.
Share this post
Link to post
