MP3 based on movement and variable
Hi all! I´ve tried to create a scene with a mp3 playing "good morning" through my sonos. I`ve borrowed part of the scen from Krikroff and his part is working perfectly.... My plan is that this scen is going to be started every morning by Sankotroniks Main scene and triggered by a motionssensor and a variable.... The scene is only suppose to play itself once in the morning and then set  the variable to zero and the kill the scene itself.... But i`ve missed something... Any Ideas?
Best regards
Pettzon
%% properties
%% events
%% globals
GoodMorningTTS
fibaro:debug(" SCENE START ")
if fibaro:countScenes() > 1 then
fibaro:debug(" SCENE ABORT - too many instances ")
fibaro:abort()
if (
 ( tonumber(fibaro:getValue(87, "value")) > 0 )
and
  fibaro:debug(" ... have movements... ")
 ( tonumber(fibaro:getGlobalValue("GoodMorningTTS")) == tonumber("1") )
then
  fibaro:debug(" ...Have got the right variable... ")
    -- 78 is the Virtual Device ID
-- 28 is the Process button ID
local sid, bid = 106, 28
-- Create STREAM params object
local params = {
  -- stream: the file / uri
  stream = "//Diskstation/data program/Fibaro Home Center/Mp3/Välkommen till familjen Pettersson.mp3",
  -- source: "local" or "http", "local" is setted by default
  source = "local",
  -- duration: play duration in seconds (option) or "auto"
  duration = 8,
  -- volume: the volume for playing the stream
  volume = 40
local _f = fibaro
local _x ={root="x_sonos_object",load=function(b)local c=_f:getGlobalValue(b.root)if string.len(c)>0 then local d=json.decode(c)if d and type(d)=="table"then return d else _f:debug("Unable to process data, check variable")end else _f:debug("No data found!")end end,set=function(b,e,d)local f=b:load()if f[e]then for g,h in pairs(d)do f[e][g]=h end else f[e]=d end;_f:setGlobal(b.root,json.encode(f))end,get=function(b,e)local f=b:load()if f and type(f)=="table"then for g,h in pairs(f)do if tostring(g)==tostring(e or"")then return h end end end;return nil end}
-- Make a request to the remote to process params object instantly
_x:set(tostring(sid), { stream = params })
_f:call(sid, "pressButton", bid)
 -- Ändra variabel
  fibaro:setGlobal("GoodMorningTTS", 0)
  fibaro:debug(" ...put variable to zero... ")
 -- Kill running scene cause it is done with appliance
  fibaro:abort();
  fibaro:debug(" ... Scene aborted! ")
Edited by pettzon
typo
" to "
Temat został przeniesiony z "
" do "
Hi @pettzon,
You put debug function in the middle of condition checking. Try bellow code:
Also you need to add motion sensor to scene header to be triggered by it otherwise it will be triggered only once when global variable is changed and if in that moment sensor is still safe then you will never hear that greeting!
    Oh! Sloppy mistakes!!! Thanks for your great help!!! :)
