Neato Connected
Hi
Does anyone have a virtual device for the Neato Connected?
It has Alexa support, so would think it can be connected to the HC2?
11 answers to this question
" to "
Temat został przeniesiony z "
" do "
Did you find any solution or plugin to this? I just bought a Neato D5 Connected and I'm very interested in adding it to me Fibaro panel.
Hi !.
Same thinks for me. I have a Neato D7, and I would like to launch it with the HC2 automatically when we aren't in the house. Do you find a solution ? Thanks.
Arnaud (from France)
You can do it by connecting FIBARO to IFTTT and connect Neato also to IFTTT.
Anyone have a Luea scene build up to update value's of a virtual device.
i looked into the documentation of Neato and i can get some info with post requests from their API but the problem is that some part of the post request needs to be converted into a HMAC256.
Anyone that can help on that one ?
can anyone maybe offer help to put this in a quickapp ?
in meanwhile i have my robot working with post requests in JSON reply but the coding issue still remains that a HMAC256 is required which i do not know how to code.
I understand that tinman made some library but also there i am afraid i have no skills in computing this.
i am currently trying to first make a correct post request in JSON to the nucleo cloud, for the moment i am stuck on a invalid date header for example as Neato requires it tobe in a specific way.
The screenshot below shows what i did in postman and it works beautifull :-)
If anyone could help we could make a contribution to finally have neato products working in Homecenter which i think should be possible since you can command them remotely.
error for the moment trying to get a good command togo out.
[03.11.2024] [18:13:26] [DEBUG] [SCENE9]: {"message":"Unacceptable range for date"}
my coding so far in HC 3 scene is the following:
local url = "https://nucleo.neatocloud.com:4443/vendors/neato/robots/OPSXXXXXXXXXXXXX/messages"
local Timestamp = os.date("%a, %d %b %Y %X GMT")
local Payload = '{"reqId": "77", "cmd": "getRobotState"}'
net.HTTPClient():request(url, {
    options={
        method = 'POST',
            headers = {
                       ["Accept"] = "application/vnd.neato.nucleo.v1",
                       ["Content-Type"] = "application/json",
                       ["Date"] = os.date("%a, %d %b %Y %X GMT"),
                       ["Authorization"] = "NEATOAPP {{signature}}"
            data = Payload,
        timeout = 5000
    success = function(response)
        hub.debug("Scene9", response.data)
    end,
    error = function(errorMessage)
        hub.debug("Scene9", "HTTPClient error" .. errorMessage)
i attached the configuration i did in postman
Solved the Date issue with a lua convertor :-)
it showed me the difference from the example on the neato developer website.
although my date was correct it did not accept it as it was missing a ! sign.
output of the lua convertor was the following based on the example of neato themselves.
translated to Lua
-- Using Lua and OpenSSL library equivalents
-- request params
local robot_serial = "123456789"
local date = os.date("!%a, %d %b %Y %H:%M:%S GMT") -- UTC date format
-- => "Fri, 03 Apr 2015 09:12:31 GMT"
local body = '{"reqId":"77", "cmd":"getRobotState"}'
local robot_secret_key = "sgbuysg5oiuemrvoiuw3g5o23rtq3yiuaegroiuaregnq3o5iyun"
-- build string to be signed
local string_to_sign = string.lower(robot_serial) .. "\n" .. date .. "\n" .. body
-- create signature with SHA256
local signature = openssl.hmac("sha256", robot_secret_key, string_to_sign)
On 10/30/2024 at 9:55 AM, marczu_83 said:
Did get so far already to create a button that is firing off a script written in the quickapp but i keep getting errors so i believe i need some coding help here.
function QuickApp:getrobotinfo()
    local robotserial = "xxxxxxxxxxx"
    local robotseriallow = string.lower(robotserial)
    local robotsecret = "xxxxxxxxxxxxxxxx"
    local date = tostring(os.date("!%a, %d %b %Y %X GMT"))
    local string_to_sign = robotseriallow .. "\n".. date .. "\n" .. requestbody
    local requestbody = '{"reqId": "77", "cmd": "getRobotState"}'
    local signature = sha.hmac(sha.sha256, robotsecret, string_to_sign)
    local binary_hash = sha.hex2bin(hmac)
    local base64_hash = sha.bin2base64(binary_hash)
    self.http = net.HTTPClient({timeout=5000})
    self.http:request("https://nucleo.neatocloud.com:4443/vendors/neato/robots/OPS02217-985DADC5A1BA/messages", {
          options = {
              data = json.encode(requestbody),
              method = "POST",
              checkCertificate = false,
              headers = {
                ["Date"] = os.date("!%a, %d %b %Y %X GMT"),
                ["Authorization"] = "NEATOAPP" + " " + signature,
              self:debug(response.status)
              self:debug(response.data)
          end,
          error = function(message)
              self:debug("error:", message)
[07.11.2024] [19:53:43] [TRACE] [QUICKAPP53]: UIEvent: {"eventType":"onReleased","elementName":"button_ID_2_1","deviceId":53,"values":[]}[07.11.2024] [19:53:43] [DEBUG] [QUICKAPP53]: ./include/Neato_Robot_Info.lua:6: attempt to concatenate a nil value (global 'requestbody')[07.11.2024] [19:53:43] [ERROR] [QUICKAPP53]: QuickApp crashed[07.11.2024] [19:53:43] [ERROR] [QUICKAPP53]: Unknown error occurred: handleJsonRpc
